迷宫追踪插件汉化版Maze Trace - 菜鸟C4D
迷宫追踪插件汉化版Maze Trace
 热度: 64 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2015-5-28 01:32 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
7028
62
Compability
相容性
The OSX version was flawed because of incorrect compilation settings and has been removed. If anyone has XCode installed and would like to help recompile the plugin please contact vidar.nelson[at]gmail.com
OSX版本有缺陷,因为不正确的编译设置已被删除。如果有人愿意帮助Xcode的安装和编译插件请联系Vidar。纳尔逊[at] gmail.com
The plugin has been compiled with the R12 sdk and should be compatible with C4D R12, R13 and R14. However, it has only been tested with C4D R14.
插件已经与R12 SDK编写应与C4D R12兼容,R13和R14。然而,只有与C4D R14测试。
Installation
安装
Unzip the folder to your CINEMA/plugins/ folder and restart CINEMA. After extraction the files (cinema4dsdk.cdl, cinema4dsdk.vcproj, etc.) should lie in CINEMA/plugins/Maze Trace/.
解压后的文件夹到您的电影/ images/文件夹重启电影。(萃取文件cinema4dsdk.cdl cinema4dsdk.vcproj应,,等)电影中的痕量、插件/迷津/。
Usage
使用
The plugin contains two objects that can be found under the plugins->Maze Trace menu entry, Maze Trace and Point Generator.
该插件包含两个对象下可以找到插件->迷宫微量的菜单条目,迷宫跟踪发生器。
Maze Trace
迷津微量
A generator (place objects under it) that takes polygon objects and connects their points in interesting ways (it tries naïvely to solve the Traveling Salesman Problem by connecting each point to its nearest neighbor).
(将物品在发电机是多边形对象将)的点的有趣的方式(这本ï尝试na的求解旅行商问题通过连接各点的邻近)。
Point Generator
点发生器
A helper object that generates random points on the surface of an input object. Since the output object only consists of points it will not show up in the 3d view unless you use it as an input to another generator, such as the Maze Trace.
一个帮助对象产生随机点的输入对象的表面。由于输出的对象仅包括点它将不会显示在3D视图,除非你使用它作为一个发电机的输入,如迷宫的痕迹。
Settings
Maze Trace
迷津微量
Maximum Segment Length
最大段长度
Delete segments longer than this. Useful for getting rid of occasional lines connecting different parts of the model.
删除片段比这更长。用于除去偶尔线连接模型的不同部分。
Relative
相对
When checked the Maximum Segment Length is a multiplier of neighboring points, otherwise it's an absolute length.
当检查最大段长度是一个乘数的相邻点,否则这是一个绝对的长度。
Point Generator
点发生器
Num Points
Num点
The number of points to generate on the surface of the object
产生于物体表面点的数量
上一篇:C4D脚本 自定义设置界面脚本custom scripts custom interface setup
下一篇:C4D叠加变形插件汉化版Tools4D MultiDeformer V2.0
谢谢..................................
2015-5-28 07:39
谢谢分享了,这样的插件很少用得到,不过收下了
2015-5-28 09:18
谢谢分享!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2015-5-28 09:56
好东西非常棒!谢谢楼主的分享!!!!!!!!
2015-5-30 11:40
{:5_117:}{:5_117:}{:5_117:}{:5_117:}{:5_117:}{:5_117:}{:5_117:}{:5_117:}{:5_117:}{:5_117:}
2015-6-19 12:09
这个有点意思啊!:lol:lol:lol:lol:lol:lol:lol:lol
2015-6-30 00:32
感谢分享
2015-7-21 15:19
真是不错的教程啊,收藏了,谢谢楼主的分享辛苦了
2015-7-22 13:35
阿什顿顶顶顶顶顶顶顶顶顶顶顶顶顶
2015-9-7 19:49
