C4D样条布尔插件汉化版MultipleSplineMask 1.0 - 菜鸟C4D
 热度: 98 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2015-5-30 09:00 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
9003
98
MultipleSplineMask is a Cinema 4D plugin that masks multiple splines at the same time using the spline mask object
MULTIPLESPLINEMASK PLUGIN
MultipleSplineMask is a Cinema 4D plugin that masks multiple splines at the same time using the spline mask object.
The principle of use is very simple:
1) put the splines into the scene
2) group them (ALT+G)
3) put the multiplesplinemask object into the scene
4) set its spline join default property
If you need you can override the join of a single spline just by adding a special multiplesplinemasktag property.
If you make the multiplesplinemask object editable you will obtain the splinemask hierarchy.
Cinema4D and system requirements:
-Cinema4D release 13/14/15
-OSX Snow Leopard or greate
-Windows 7 32/64 bit or greater
multiplesplinemask是Cinema 4D插件,面具多条同时使用样条遮罩对象
multiplesplinemask插件
multiplesplinemask是Cinema 4D插件,面具多条同时使用样条遮罩对象。
使用的原理很简单:
1)把样条进入现场
2)组(ALT + G)
3)把multiplesplinemask对象到场景
4)设置样条加入默认属性
如果你需要你可以重写加入单一样条只通过添加一个特殊的multiplesplinemasktag财产。
如果你让multiplesplinemask对象编辑你将获得splinemask层次。
Cinema4D和系统要求:
- 13 / 14 / 15 Cinema4D释放
- OSX雪豹或更大
- Windows 7 32 / 64点或更大
上一篇:C4D预览校准器插件汉化版 View Calibrator 1.1
下一篇:C4D坐标插件:Lost a Point 2.1.9
我一直觉得楼主的品味还不错。。。。。。。。。。。。。。
2015-5-30 10:08
谢谢分享!!!!!!!!!!!!!!!!!!!!
2015-5-30 10:23
2015-5-30 10:32
谢谢楼主分享“C4D样条布尔插件汉化版MultipleSplineMask 1.0”......
2015-5-30 11:55
好东西非常棒!谢谢楼主的分享!!!!!!!!
2015-5-30 12:09
谢谢,非常感谢!!!!!!!!!!!
2015-5-30 15:11
谢谢楼主分享!!!!!!!!!!!!!!!!!!!!!!
2015-5-30 19:36
不舛的分享了呀!!!!!!!!!
2015-5-31 12:15
不錯的資源,下載下來學習了,謝謝。
2015-6-1 18:42
