C4D点变形插件汉化版Point Morph 2.0 - 菜鸟C4D
 热度: 66 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2015-5-30 11:00 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
6900
65
POINT MORPH PLUGIN
Point Morph is a Cinema 4D R13/14/15 plugin that helps user to create and animate complex poses quickly.
We developed this plugin in order to bypass some frustrating limitations of the PoseMorph Tag which is actually one of the best and easy tool to create and animate poses in Cinema 4D.
Point Morph works by copying the base pose into a new a new object so you can use tools like iron and slide that usually don't work with PoseMorph because they modify the base pose even if you are working on a custom pose.
You can use all kinds of tools but of corse the custom pose need to have the same number of vertices of base pose.
Another interesting feature of Point Morph is the add track spline function.
By default the Pose Morph mix the poses using the linear transition, this is not a limitation but if you want to fix this behaviour you need to waste a lot of time finding the correct rotation point of the pose because there is no visual tool that helps you during this process.
Point morph can creates a spline for each point you need to animated over a path.
You can also flip your pose and spline tracks automatically with the Point Morph tools.
Point morph also creates automatically for you a controller object with user datas and xpresso script configured and ready to use......only in one click.
Last but not the least PoseMorph is available only Studio edition of Cinema, Point morph is free and downloadable from our store and works with all editions: PRIME, BROADCAST, VISUALIZE, STUDIO
What's new in release 2.0:
- New feature "Select Animated Points"
- New feature "Create connected spline tracks"
- Performance speed up
- Fully backward compatible with release 1.0
If you need more information watch the new video about Point Morph 2.0
Install the update by deleting the old folder and replace it with the new one.
Note about correct use of Point Morph:
Before animating the poses you have to model all of them because the Optimize and Create Controller command create from scratch the xpresso script and user datas causing the loss of stored keyframe.
Cinema4D and system requirements:
-Cinema4D release R13/14/15
-OSX Snow Leopard or greater
-Windows 7 32/64 bit or greater
上一篇:C4D屋顶瓦片生成插件汉化版Tuile Generator 2.0.10
下一篇:C4D插件Burn Alert 1.0
谢谢..........................................
2015-5-30 11:49
谢谢楼主分享“C4D点变形插件汉化版Point Morph 2.0”......
2015-5-30 11:51
好东西非常棒!谢谢楼主的分享!!!!!!!!
2015-5-30 12:07
谢谢版主的贡献,辛苦啦........................
2015-5-30 14:06
好东西,谢谢,非常感谢!!!!!!!!!!!!!
2015-5-30 15:14
谢谢楼主分享
2015-5-30 15:20
好东西啊 看看先好东西啊 看看先好东西啊 看看先
2015-5-31 09:55
不舛的分享了呀!!!!!!!!!
2015-5-31 12:35
不錯的資源,下載下來學習了,謝謝。
2015-6-1 18:37
