软件···Win/Mac怎样完美卸载 C4D - 菜鸟C4D
首页 › 综合交流 › 技术交流 发布时间:2022-4-17 21:13 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
5268
网上没看到比较官方的卸载教学,
后来在官网找到一个 R20 的安装说明文档 pdf
看下说明文档是怎样说的:
Windows
软件···Win/Mac怎样完美卸载 C4D-1.jpg
Go to the system settings, select Programs and Functions and double-click on the Cinema 4D R20, BodyPaint 3D R20, Team Render Server R20, Team Render Client R20 or MAXON License Server item. The de-installation dialog window will open.
01 Activate this item if you want to completely remove the program from your computer.
02 Activate this option if you also want to remove your user directory. This directory contains your personal program settings as well as other information.
Attention: If this directory is deleted, your own Content Browser libraries and all other data that you have saved here will be deleted. Only activate this option if you no longer require these files!
03 This option defines if the plugins should also be deleted during the deinstallation. This option should be disabled if you have third-party plugins that you want to continue using.
Attention: This option is enabled by default.
Note: The RLM directory, which is located under C:\Program Files\MAXON, will not be deleted and must be removed manually.
翻译一下:
转到系统设置,选择“程序和功能”,然后双击Cinema 4D R20,BodyPaint 3D R20,Team Render Server R20,Team Render Client R20或MAXON License Server项目。卸载对话框窗口将打开。
01假如要从计算机中完全delete程序,请激活此项目。
02假如您还想delete用户目录,请激活此选项。该目录搜罗您的个人程序设置以及其他信息。
注意:假如delete此目录,则将delete您本人的内容阅读器库以及在此保留的所有其他数据。仅在不再需要这些文件时才激活此选项!
03此选项定义能否在卸载过程中也delete插件。假如您有要继续使用的第三方插件,则应禁用此选项。
注意:默认条件下启用此选项。
注意:位于C:\ Program Files \ MAXON下的RLM目录不会被delete,必须手动delete。
macOS
To uninstall the program, move the folder Cinema 4D R20, BodyPaint 3D R20, Team Render Server R20, Team Render Client R20 or MAXON License Server to the trash.
Your personal user data can be found on the hard drive under Macintosh HD/User/ [username]/Library/Preferences/MAXON. If you also want to delete this information, drag this folder into the trash as well.
Attention: If this directory is deleted, your own Content Browser libraries and all other files stored here will be deleted!
翻译一下:
要卸载程序,请将文件夹Cinema 4D R20,BodyPaint 3D R20,Team Render Server R20,Team Render Client R20或MAXON License Server移到回收站。
您的个人用户数据能够在Macintosh HD / User / [用户名] / Library / Preferences / MAXON下的硬盘驱动器上找到。假如您还想delete此信息,请将此文件夹也拖到垃圾箱中。
注意:假如delete此目录,则您本人的内容阅读器库以及此处存储的所有其他文件都将被delete!
<hr/>希望对大家有协助,附件功能无法使用,需要说明文档的能够私信我!!!
上一篇:C4D 有动力学标签仍然穿模怎样办?
下一篇:Octane渲染器设置
