before quitting you have one chance to save your project (don't use the same name as the original)
在退出之前你有一个机会来保存您的项目(不使用相同的名称来保存)
AE waring :unable to create drawing surface
AE警告:无法创建绘图表面
AE error:crash occurred while invoking rendering plug-in "AE_OpenGl "
AE错误:事故发生在调用渲染插件”ae_opengl”
AE error : could not convert unicode characters
AE错误:无法转换Unicode字符
please uninstall and reinstall the product。
if this problem still occurs,please contact adobe technical support for help,and mention the error code shown at the bottom of this screen
error:3
请卸载并重新安装该产品
如果问题仍然存在,请帮忙联系Adobe的技术支持,并说该屏幕底部显示的错误代码
错误:3
After Effects error: Unable to allocate space for A×B image buffer.
You may be experiencing memory fragmentation.In the Memory & Cache Preferences dialog box, try increasing the RAM to leave for other applocations, and selecting the Enable Disk Cache option in the Media & Disk Cache panel.
(7::66)
After Effects错误:无法为×B图像缓冲区分配空间。
你可能会遇到内存碎片。在内存和高速缓存参数对话框,尝试增加RAM离开其他的应用, 并选择使媒体和磁盘高速缓存磁盘缓存选项面板。
(你没有内存了)
