C4D路径变形插件汉化版 Tarabella Path Deforme v1.6 R14-R17 WIN - 菜鸟C4D
 热度: 143 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2015-9-22 23:43 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
9878
142
Path Deformer可以让物体沿着样条线进行扭曲操作,同时保留物体原来的属性
Path Deformer is a Plugin that allows you to get a unique deformer with great possibilities. Simply choose a spline your object will be distorted upon that spline without loosing proportions. Path Deformer twist the object upon a curve and lets you to roll the objects upon the spline and to control the position along the path. You can also place a reference object under the deformator to have an accurate reference for position and rotation along the path. Path Deformer is the best way to deform objects over a spline.
Installing Path Deformer
To installing Path Deformer unzip the related zip file in the folder "plugin" of Cinema 4D.To using Path Deformer, first time you must put the serial number (obtained at the time ofpurchase).
When you launch Cinema 4D after Path Deformer installation will appear this window. Click OK and theCinema 4D Registration form will appear.
Paste the NOTAEffector key into the NOTAEffector field as shown in the image below.
Click OK button and now you can play Cinema 4D and you will find in the “PLUGINS” menu a new entry:
上一篇:C4D预设 灯光预设v1.1mmvf lights v1.1
下一篇:C4D权重绘制插件佳成汉化版 Delta Mush v1.0
提示: 作者被禁止或删除 内容自动屏蔽
2015-9-22 23:51
不错!谢谢楼主无私分享!!!!!!!!
2015-9-23 01:31
谢谢。。。。。。。。。。。。。。。。。。。。。。。。。。。
2015-9-23 07:36
谢谢楼主无私分享
2015-9-23 08:15
谢谢楼主分享:”C4D路径变形插件汉化版 Tarabella Path Deforme v1.6 R14-R17 WIN“
2015-9-23 09:11
这么快又汉化的了,谢谢分享!!!
2015-9-23 09:39
不错!谢谢楼主无私分享!!!!!!!!
2015-9-23 16:27
不錯的資源,好东西非常棒!谢谢楼主的分享!
2015-9-23 19:14
非常牛的插件 感谢分享非常不多的加油加油
2015-9-23 22:53
