对称固定插件SymmetryClamp v1.1 - 菜鸟C4D
 热度: 230 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2015-10-25 16:53 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
14676
242
以下内容 回复可见Symmetry Clamp 1.1
Installation:
[All versions]
Close Cinema 4D.
Unzip the 'SymmetryClamp1-1' folder into the Cinema 4D 'plugins' folder.
[R9.1]
The 'Symmetry Clamp 1-1.c4d' file inside the 'SymmetryClamp1-1' folder contains the tag
connected to its User Data and applied to an object.
This setup must be loaded in order to use the plugin.
Note: Symmetry Clamp has been created using the R9.5 SDK. It is recommended that the plugin
be used with R9.5 or higher.
[R9.5 and R9.6]
Open the 'Symmetry Clamp 1-1.c4d' file inside the 'SymmetryClamp1-1' folder.
In Cinema 4D, click on the Symmetry Clamp 1.1 tag.
From the Edit menu in the Attributes Manager, select Set As Default.
Tag settings can also be saved from the Object Manager using File > Save Tag Preset.
The tag can also be dragged to and loaded from the Content Browser.
[R10]
A bug in R10 prevents the saving of tag settings via the Attributes Manager (ver R10.008).
The tag settings can be saved from the Object Manager using File > Save Tag Preset.
The tag should be set up with Lock Zero Points unchecked as default. After applying a
tag and aligning zero points, remember to check Lock Zero Points before beginning
constrained-point editing.
If removing Symmetry Clamp 1.0, tag presets can be deleted via the Content Browser.
Usage:
When Lock Zero Points is unchecked, all points can be moved freely.
When Lock Zero Points is then checked, any points currently at zero on the Mirror Plane's
perpendicular axis will be constrained.
Any points subsequently moved to zero will remain unconstrained until:
* Lock Zero points is unchecked and then checked again; or
* the point count of the object changes.
A centre poly perpendicular to the Mirror Plane will always be grouped with its mirrored
poly when extruded. A non-perpendicular poly will be grouped with its twin when Lock Zero
Points is checked and will be extruded separately when Lock Zero Points is unchecked.
When Lock Zero Points is checked, zero points will remain constrained when the mesh object
is moved, rotated or scaled.
Thanks to:
Matthias Bober for integrating the expression into a plugin tag and
creating the tag icon;
tcastudios for bug reports and coding assistance; and
Lorenzo de Trizio (aka MrBraun) for bug reports and feature requests.
Copyright and Disclaimer:
Symmetry Clamp ?007 David Wickenden
Symmetry Clamp is distributed as-is and no warranties are given.
I will not accept liability for any damage or loss of data resulting from the use
of this plugin.
This plugin is free for personal and commercial work.
上一篇:C4D脚本 Easy Light 1.0灯光脚本
下一篇:[R13+]闭合样条插件OneSpline 0.3
提示: 作者被禁止或删除 内容自动屏蔽
2015-10-25 22:47
谢谢楼主分享:]对称固定插件SymmetryClamp v1.1......
2015-10-26 10:02
谢谢分享!!!!!!!!!!!!!!!!!!!!
2015-10-27 18:03
thank you very much12345678900987654321
2015-10-28 09:18
非常好的东西我好喜欢哦。。。。。谢谢了。感谢您辛苦楼主了!
2015-11-20 19:30
谢谢分享
2015-12-18 20:27
好东西非常棒!谢谢楼主的分享!!!!!!!!
2016-1-4 02:22
C4D之家,如果您要查看本帖隐藏內容請移至帖子底部回复框回復
2016-1-21 00:50
传说升级到R12就可以使用快速回复,升级更快!
2016-1-21 14:47
