AE移动锚点脚本 MoveAnchorPoint v2.0 - 菜鸟C4D
 热度: 54 [ 复制链接 ]
首页 › 后期处理 › AE插件 发布时间:2015-12-29 14:35 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
11127
55
本脚本属于其他分类,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC、CC2014、CC2015、CC2016、CC2017、CC2018、更高,当前工具无教程,支持Windows系统安装使用。这个素材由用户80年代的白衬衫分享在AE插件区,更多关于的内容请访问菜鸟c4d网站!
Special thanks to Oplique for helping me test and improve this version of the script.
Added 'Move to Custom Point' option
Move anchor point now works with masks applied to the layer by default
The 'Ignore Masks' option was added to disregard masks applied to the layer
Layers with parents are now repositioned correctly
Layers with non-uniform scale values now are repositioned correctly.
Several other minor bug fixes and improvements
[fold=点击展开更多介绍]WHAT IS MOVE ANCHOR POINT?Move anchor point allows you to quickly move the anchor point of a layer to a new location without changing the visible position of the layer. The anchor point can be moved to one of nine preset positions, and new in version 2.0 it can also be moved precisely to a custom position.INSTALLINGIn the .zip file you downloaded, you will see the 'Move Anchor Point.jsx' and the 'map_images' folder. Select and copy both items.You need to paste them into the 'ScriptUI Panels' folder for your version of After Effects. (You must have After EffectsCS3 or higher to use the Move Anchor Point script.)Mac: ~/Applications/Adobe After Effects YOUR VERSION/Scripts/ScriptUI PanelsWindows: C:/Program Files/Adobe/Adobe After Effects YOUR VERSION/Support Files/Scripts/ScriptUI Panels** If you do not have any ScriptUI Panels installed already, you should verify the spelling and placement of the 'ScriptUI Panels' folder. Capitalization and spacing is important. If the folder is not correctly named and in the correct location, the script will not be visible in the 'Window' menu.Now start up After Effects. You will see 'Move Anchor Point.jsx' at the bottom of the 'Window' menu. Select it to open the Move Anchor Point panel. If After Effects was already open, you must restart the program before it will be visible in the 'Window' menu.USING MOVE ANCHOR POINTYou have a few options when using Move Anchor Point. The main way is to use one of the nine presets.move anchor point presetsEach of these black icons represents a different point on the layer. Simply select your layer, or multiple layers, then click on one of the buttons and your anchor point will snap to that position.Underneath the presets is the Ignore masks checkbox:move anchor point ignoreBy default, if there are masks applied to your layer, only the portion within the mask will be taken into account. C4D Checking this box would move the anchor point relative to the layer as if the mask was not there. If the mask is set to 'None', it will automatically be ignored. If there are multiple masks applied, the resulting position will take all masks into account.The last part of Move Anchor Point is the Custom Point sectionmove anchor point customThe lets you move the anchor point to a precise custom location. To use the custom point, just enter a percentage (Percentages must be entered as fractions or decimals. Ex: 75% could be entered as .75 or 3/4 ) for both the X and Y amount. So if you wanted the anchor point to be 25% of the way across the layer and 85% down it, you would enter .25 for X and .85 for Y. Then just click 'Move to Custom Point'The area of your layer is represented by numbers between 0 and 1, however you are able to use numbers outside this range if you would like to move your anchor point outside the boundaries of your layer.[/fold]
上一篇:AE插件:E3D v2.2.2三维模型插件完美xx版VideoCopilot Element 3D v2.2.2
下一篇:AE非关联批量复制脚本中文版True Comp Duplicator
传说升级到R12就可以使用快速回复,升级更快!
2015-12-29 23:38
那好   我就来努力的升级,力争到R20的节奏。哈哈哈哈哈哈
2015-12-30 11:43
好东西非常棒!谢谢楼主的分享!!!!!!!!
2016-1-3 00:16
我也想要插件,谢谢楼主分享!!!!!!!!!!!!
2016-4-9 15:46
AE移动锚点脚本MoveAnchorPoint v2.0
2016-12-2 10:18
2017-10-19 10:57
2018-5-11 21:09
2018-5-30 15:11
2018-6-7 02:08
