每次操作的点击次数最多减少 10 倍
如果您愿意更改一些行为并使用带有快捷方式的脚本,您将很快感受到使用 HB ModellingBundle 意味着什么。可以肯定地说,您在 C4D 中为建模执行的最频繁操作现在只需少 2-10 倍的点击即可完成。
What Is It?
HB ModellingBundle is a set of over 60 scripts for Maxon’s Cinema 4D which are dedicated to 3D modelling.
The goal of these scripts is to improve workflows and perform many operations a great deal faster, this means less clicks and less mouse movement. With HB ModellingBundle you receive not only 60 plus scripts but also a very well chosen set of shortcuts, a modelling layout for C4D and a template C4D scene which shows tools settings in the viewport which makes working in fullscreen mode much easier.
HB ModellingBundle is the result of Holger Biebrach’s 10 years experience with Cinema 4D as a professional 3D Generalist. Early in his career he began creating custom scripts to make any repetitive process in C4D much faster. Over the years he has added a lot of ‘stuff’ and the collection is still growing. To get a better idea about the bundle, please watch the many videos below which show you the potential of this feature packed product.
UP TO 10 TIMES LESS CLICKS PER OPERATION
If you are willing to change some behaviours and use scripts with shortcuts, you will very quickly feel what it means to work with HB ModellingBundle. It is safe to say that the most frequent actions you do in C4D for modelling, will now be accomplished in 2-10 times fewer clicks.
