CD Character Bundle Pro 1.5
This bundle includes CD IK Tools, CD Joints & Skin, CD Morph and CD Constraints. These are commercial license plugins, but they are also set up to function with a demo version of Cinema 4D. You will need to purchase a serial number for them to work with a licensed version of Cinema 4D. You may download the CD Character Bundle Pro from this page and try it out with the demo version of Cinema 4D. Then if you decide to purchase the CD Character Bundle Pro serial numbers, just return to this page, and click on the Buy Now button.
这束包括CD IK工具、关节和皮肤的CD,CD和CD约束变形。这些都是商业许可的插件,但他们也设置的功能与CINEMA 4D的演示版,您将需要购买一个序列号他们与一个4D影院行货版本的工作。你可以从这个网页下载CD特征束亲试一下用Cinema 4D演示版然后,如果你决定购买CD特征束亲序号,只是回到这个页面,点击立即购买按钮。 CD Transfer Tools 1.0
This plugin is a set of command tools, which makes transferring objects in the scene much easier. The commands included for transferring objects are: CD Transfer, CD Transfer Mirror, CD Transfer Replace, CD Transfer Swap, CD Transfer Align and CD Transfer Links. There is also a CD Coordinates Manager included that can be used as a replacement for the regular coordinates manager. The CD Coordinates Manager allows you to work in real world units, allowing you to convert between units of measure and set the unit scale.
This is a commercial license plugin, but it is also set up to work in demo mode and to fully function with a demo version of Cinema 4D. You will need to purchase a serial number to get full functionality with a licensed version of Cinema 4D. You may download CD Transfer Tools from this page and try it out.
