对象结构数据生成插件汉化版Caleidos4D Arch01 v3.00 - 菜鸟C4D
精选插件 对象结构数据生成插件汉化版Caleidos4D Arch01 v3.00
 热度: 338 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2016-1-19 18:20 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
22175
359
2.png C4D 插件 Dimension 是用于测量和标尺操作的 Cinema4D 插件 它测量:距离、角度、测高,只需点击几下
Arch-01 is a modeling toolset that allows the user to draw geometry inside Cinema 4D with classic CAD like precision and workflow. Arch-01 contains: 6 Main Tools + 7 Minor Tools + Arch-01 ManagerMain Tools1 – Draw Line/Arc2 – Draw Circle3 – Draw Square4 – Precision Mover5 – Surface Aligner6 – Object DimensionMinor Tools7 – Make Polygons8 – Excalibur9 – Cut Polygons10 – Copy Polygons11 – Paste Polygons12 – Clone Polygons13 – iSolaEach Tool is controlled for common settingby the Arch-01 ManagerWith Arch-01 you canrawing Tools- Draw Linear Spline as CAD like precision- Draw Arc Spline as CAD like precision- Draw Circular Spline as CAD like precision- Draw Rectangle Spline as CAD like precisionPosition Tools- Move an object from point to point as classic CAD like precision- Place an object or object copy on polygons normal- Replace objects with Instanze Modeling Tools- Make a Polygon from Spline- Cut a Polygon with Spline- Cut selection Polygons- Copy selection Polygons- Paste selection Polygons- Clone selection Polygons- Isolate the selection Objects Measurement Tools- Get Distance between 2 points in real Time - Get Length Spline in Real Time- Get Area from Selection Polygons in Real Time- Add Parametric Objects for quote (distance, altimetric, angular) in real Time
C4D插件教程 对象结构数据生成插件汉化版Caleidos4D Arch01 v3.00
https://www.c4dcn.com/thread-12541.html
上一篇:栏杆楼梯插件汉化版Caleidos4D Baluster4D v1.00
下一篇:C4D预设 花样文本生成器Text Edge FX Pro 2.0
C4D插件汉化,就上C4DCN.com !!!
阿梓喵
2018-5-8 15:57
C4D插件汉化,就上C4DCN.com !!!  详情 回复
2016-1-19 18:21
2016-1-19 18:25
感谢楼主分享
2016-1-19 18:27
传说升级到R12就可以使用快速回复,升级更快!
2016-1-19 18:44
谁都别拦我,我要回帖攒金币,我要换购vip!
2016-1-19 18:44
2016-1-19 18:56
2016-1-19 18:56
2016-1-19 19:05
不错!!!,谢楼主无私分享~~~~~~~~~~~~~~
2016-1-19 19:12
