C4D动画收割机插件汉化版TotalEmersionStudios Harvester v3.00 - 菜鸟C4D
首页 › 分类资源 › C4D插件 发布时间:2016-1-26 10:57 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
6352
48
Manual.pdf (643.76 KB, 下载次数: 2)
The Harvester plug-in allows Cinema 4D users to save animation of a hierarchy of objects "rig", and then apply that animation to similar rigs. It also is used to transfer animation from dissimilar rigs. Customize which objects will be animated, the time for animation to be saved, inserted, or transferred. Options are provided to allow excluding/including tags, movement, rotation, scale, or userdata animation.
该收割机插件允许C4D用户保存一个层次结构对象的“造”的动画,然后应用动画类似的钻井平台。它也被用于从不同的钻机传送动画。自定义哪些对象将被动画化,动画保存,插入或转移的时间。提供选项,允许不包括/包括标签,移动,旋转,缩放或用户数据的动画。
3.0新功能
This update introduces the new transfer feature. Transfer allows users to take animation from a rig with a very different structure from another rig and transfer it over. This is done by getting the two character rigs into a reference pose at a given time. This can be useful when you have similar character but varying in size or some other detail. It is also helpful when you have used this plug-in to save a bunch of animation for a particular rig and now want to use some of those animations on other rigs. Some additional changes provided by this update are list below.
Removed support for R14 and below and added support for R15 to R17.
Updated and optimized the layout of the GUI to maximize workspace.
Added the ability to hide objects based on their layers.
Added layer information and icons next to source lists in order to avoid instances where there are multiple objects with the same name being mapped incorrectly.
Added the ability to set the last keys interpolation for all the keys at the end of the inserted animation.
Resolved various minor bug fixes.
此更新引入了新的传输功能。传输允许用户从另一台带动画从钻机具有非常不同的结构和转移过来。这是通过获得两个字符钻机成参考姿势在给定的时间内完成。当你有类似的特点,但在大小或其他一些细节变化,这很有用。它也是有用的,当你使用这个插件节省了一堆动画的一个特定的装备,现在想用其中的一些动画其他钻机。此更新提供了一些额外变化的文章。
删除支持R14和下方,增加了对R15到R17。
更新和优化GUI的布局来最大化的工作区。
增加了隐藏根据其图层的对象。
新增旁边源列表,以避免在有相同名称映射错误的多个对象实例层信息和图标。
添加到设置的最后一个键插在插入的动画结束所有键的功能。
解决各种小错误修复。
上一篇:菜鸟HDR v1.4一键中英文脚本预设
下一篇:C4D星球大战BB8机器人脚本预设含教程
C4D插件汉化,就上C4DCN.com 专注C4D资源分享
2016-1-26 11:03
谢谢分享~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2016-1-26 11:10
谢谢本杰明分享
2016-1-26 11:10
谢谢本杰明分享
2016-1-26 11:11
感谢楼主的分享,非常棒,加油加油.....
2016-1-26 11:16
2016-1-26 11:16
感谢楼主分享,谢谢!!!!!!!!!!!!!!!!!!!!!
2016-1-26 21:31
楼主这个帖子实在太内涵,先赞一个!
2016-1-27 09:35
谢谢分享了呀!!
2016-1-28 14:06
12345下一页
