C4D藤条植物生长插件汉化版KDZ Vinema4D v1.00 - 菜鸟C4D
精选插件 C4D藤条植物生长插件汉化版KDZ Vinema4D v1.00
 热度: 496 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2016-5-22 17:36 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
32728
526
可以在C4D中制作植物枝条藤条生长动画,控制生长时间,状态等,支持C4D联机网络渲染
A little bit IvyGrower, a little bit Greebler.  Vinema4D adds procedurally grown and animatable vines to Cinema 4D R16 and newer.  IvyGrower users have had some awesome feature requests over time and it took a while between other life-distractions to do the research, do the testing, and work out the details in my head, on paper, and then in practice.  Vinema4D is procedural; it is fast, it is configurable, it is multi-processing, and should work with Net/Team Render.  There are many features and presets still on the table for this plugin.
安装步骤:
将Vinema4D_R16_0100拷贝到C4D插件文件夹:C:rogram FilesMAXONCINEMA 4D R16plugins
运行注册机Kuroyume_Multigen_V2_MUS3.exe,下拉菜单选择Vinema4D 1.00,CINEMA 4D Serial填写你C4D的序列号(怎么查看序列号,打开C4D,菜单栏帮助Help,Personalize个性化,弹窗右侧可以看到C4D序列号),点击Generate,得到插件序列号,用插件的时候输入就行
上一篇:C4D运动图形效果器插件汉化版Tools4D Additional Effectors Vol 1 v1.27 MUS3
下一篇:C4D舞台射灯插件汉化版hantMade Stage v1.1 rev233 DevLic R17 MUS3
这款插件和IvyGrower类似?
打开C4D时提示 Vinema4D缺少默认提示框???这个能解决吗???
楼主是否可以分享下插件应用的简单步骤??
谢谢
2016-5-23 13:02
多谢分享
2016-5-22 17:37
顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶
2016-5-22 17:59
楼主很专业,牛逼吹的一流的,看来菜鸟不菜鸟啊!
2016-5-22 21:01
楼主这个帖子实在太内涵,先赞一个!
蒙之之
2018-3-29 02:22
C4D藤条植物生长插件汉化版KDZ Vinema4D v1.00  详情 回复
2016-5-23 02:57
楼主这个帖子实在太内涵,先赞一个
2016-5-23 07:37
楼主这个帖子实在太内涵,先赞一个!
2016-5-23 09:03
2016-5-23 11:26
提示: 作者被禁止或删除 内容自动屏蔽
2016-5-23 15:50
