C4D权重脚本 Cineversity Premium Weight Scripts MUS3 - 菜鸟C4D
 热度: 93 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2016-6-8 14:03 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
10011
96
这个脚本属于绑定、其他分类,支持cinema4d软件版本为:R12、R13、R14、R15、R16、R17、R18、R19、R20、R21、S22、R23、R24、R25、R26。语言为英文,系统支持Windows、MAC。可以在软件脚本菜单位置找到本工具。当前素材由设计师用户:admin分享,更多关于脚本、绑定插件、Cineversity插件、权重脚本的内容请访问本网站。
Optimize your Cinema 4D Character Weighting workflow with the CV-Weights Scripts, developed by top character TD Bret Bays. This multi-script pack adds several methods of importing and exporting weights to a separate file, blending weights along a path or based on neighboring vertices, copying and pasting weight values and assigning weight values via keyboard shortcuts.
Free yourself from tedious tweaking within the Cinema 4D Weight Manager, and bind characters with a straightforward, visual workflow.
Included scripts:
CV-Blend Weights Along Path: Blend weight values between two vertices
CV-Hammer Weights: Blend weight values based on weighting of neighboring vertices
CV-Copy / Paste Weights: Copy and Paste weight values between vertices
CV-Import / Export Weights: Import or Export weight values to separate text-based file(s) containing the weight data for each object
CV-Weight Strength: A set of scripts that can be bound via keyboard shortcuts to quickly set an absolute weight strength or adjust the weight strength in increments of 1%, 5% or 10%
CV-Apply Weights to Selection: Quickly apply the current strength to selected components via a keyboard shortcut
上一篇:阿诺德Arnold渲染器插件 SolidAngle C4DtoA 1.0.15.0 - R15-R17 [WIN] [MAC]
下一篇:C4D工程优化点线面内存插件R17专版 Vision4D PowerReducer R17 MUS3
谢谢分享!!!!!!!!!!!!!!
2016-6-8 15:30
楼主很专业,牛逼吹的一流的,看来菜鸟不菜鸟啊!
2016-6-8 15:39
2016-6-8 15:39
谁都别拦我,我要回帖攒金币,我要换购vip!
2016-6-10 17:05
2016-6-13 08:48
C4D插件汉化,就上C4DCN.com 专注C4D资源分享
2016-6-13 09:36
2016-6-13 09:36
33333333333
2016-6-13 10:53
33333333333
2016-6-13 10:54
作用分类: 绑定 » 其他
插件分类: 脚本
支持语言: 英文
出现位置: 脚本菜单
检索码: -
