19部C4D R18教程抢先观看:Cineversity Cinema 4D Release 18 Learn - 菜鸟C4D
 热度: 164 [ 复制链接 ]
首页 › 分类资源 › C4D教程 发布时间:2016-7-28 19:48 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
8784
166
课程名称:19部C4D R18教程抢先观看:Cineversity Cinema 4D Release 18 Learn
知识点:新手基础入门教程、R18教程、Cineversity教程 C4D教程
教程方向:基础入门
授课语言:英文
工程素材:无
渲染插件:自带标准
下载权限:免费资源
  • Add 3D Objects to Footage using the Object Tracker
  • Artistically Control the Influence of MoGraph Effectors with Weighting
  • Cinema 4D Release 18 Highlights on Vimeo
  • Create Repeated Offset Cuts with C4D's Plane Cut Tool
  • Cut Lines and Splines in Polygon Models with C4D's Line Cut Tool
  • Destruction Effects with Voronoi Fracture
  • Eliminate Overlapping Clones with the Push Apart Effector
  • Enhance the effect of Bump Maps using Parallax
  • Honeycomb Array, Scale to Fit Polygons, and other MoGraph Cloner Enhancements
  • Insert Symmetrical Loops in Polygon Models with C4D’s Loop Cut Tool
  • Randon Graphic Textures with the Variation Shader
  • Reset MoGraph Cloners and Share Falloffs with the ReEffector
  • Simulate Subsurface Effects and Worn Edges with Inverse Ambient Occlusion
  • Slice, Dice, & Julienne Objects with Voronoi Fracture Sources
  • Store MoGraph Caches Externally and Mix Multiple Caches
  • Use C4D's Thin Film Shader to Render Oily Surfaces and Bubbles
  • Use OpenSubdiv Smoothing for Compatibility, Performance, and Flexibility
  • Use Shadow Catcher to Create Alphas from Shadows for Easy Compositing
  • View Enhancements- Screen Space A.O. Reflection Previews, & GPU Displacement
上一篇:C4D利用置换贴图制作高度地图景观教程 Height Map Landscapes in Cinema 4D
下一篇:C4D阿诺德制作旋转样条
东西不错,支持楼主继续分享更棒的资源给大家。
2016-7-29 03:59
2016-7-29 08:03
2016-7-29 08:25
传说升级到R12就可以使用快速回复,升级更快!
2016-7-29 09:00
2016-7-29 09:22
2016-7-29 09:23
2016-7-29 11:49
2016-7-29 12:10
2016-7-29 12:13
