课程名称:C4D制作舞蹈人物变形动画教程 SkillShare – Animating with Deformers in Cinema 4D
知识点:绑定蒙皮教程、人物动画教程、变形动画、变形教程、舞蹈 C4D教程
教程方向:基础入门、机械动画
授课语言:英文
工程素材:有
渲染插件:自带标准
下载权限:VIP精选
In this course you will learn how to use deformers to animate simple dancing characters in Cinema 4D. By the end of these lessons, you will have the skills necessary to create a professional animation, complete with lighting and sound, using Cinema 4D and After Effects.
You’ll learn the importance of:
3D Modeling
Use simple parametric primitives to model basic characters for animation.
Use the ‘make editable’ function in conjunction with extrusions to add detail to your characters.
Animation
Use deformers to make the characters dance.
Refine the characters movements using Cinema 4D’s dope sheet and timeline F-Curve editor.
Animate cameras throughout the scene and learn to use the stage object to switch between cameras.
Texturing
Learn how to apply textures to the characters and environment
Animating texture parameters
Lighting
Learn to use spot lights with the visibility and noise enabled to highlight the musicians.
Use of fill lights for the dancers and disco balls.
Spot lights with gobo effects animation using the ‘align to spline’ tag.
Create rays of light using the MoGraph cloner, cylinders, and semi-transparent materials.
3D Rendering
Learn about Cinema 4D’s render settings and how to export your 3D animation. Output, size, film aspect, frame range, save function/path, and anti-aliasing will be covered.
Post Production in After Effects
Vignettes, masking, track mattes, color correction, noise, blur, and creating smoke effects using fractal noise.
