C4D边缘点材质渲染插件汉化版 Tools4D WireShader Pro Plus - 菜鸟C4D
 热度: 205 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2016-8-30 21:37 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
14983
206
Tools4D Wireshader Pro v1.6 MUS3
Tools4D WireShader Pro single 1.6
Wireshader Pro是C4D的材质插件,可以按照条件自由渲染模型结构线,非常方便快捷!
Wireshader Pro+ is a C4D plugin shader which gives you the ability to procedurally render object edges and points through a shader.
This has many advantages over a simple bitmap. Written in c++, this shader is very fast, flexible and very easy to use.
It works with Advanced Render, Physical and of course Vray. This New version has lots of settings for different edge styles, which  you can then drive with other shaders, for some really cool and original edge and point effects.
It renders real edges which you can hide with an edge selection, as well as artificial edges and points, including SPD edges.
Wireshader临+是,让你通过一个着色器程序上渲染物体边缘和点的能力C4D插件着色器。
这具有在一个简单的位图的许多优点。用C ++编写,这种着色器是非常快速,灵活,很容易使用。
它的工作原理与高级渲染,物理课程和Vray的。这个新版本有很多不同的边缘样式,然后你就可以与其他着色器驱动器,对于一些非常酷和原边和点效果设置。
它使得真正的边缘,你可以边选择隐藏,以及人为的边缘和点,包括SPD边缘。
上一篇:C4D Vray渲染器摄影棚HDR环境预设 VRay Studio Tools 1.3.5 PRO
下一篇:阿诺德渲染器v1.2插件汉化版 SolidAngle C4DtoA 1.2.0 for Cinema 4d R15-R18
2016-8-30 21:46
2016-8-30 22:06
东西不错,支持楼主继续分享更棒的资源给大家。
2016-8-30 22:08
2016-8-30 22:09
感谢分享
2016-8-30 22:12
感谢分享
2016-8-30 22:12
2016-8-30 22:45
2016-8-31 00:35
感谢分享,非常试用的插件,支持楼主
2016-8-31 08:11
