Houdini Engine for Cinema 4D Houdini引擎接口插件 - 菜鸟C4D
 热度: 90 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2016-9-5 16:57 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
9680
92
中文注释.txt (1.86 KB, 下载次数: 21)
Cinema 4D终于和Houdini“联姻”成功啦!借助刚发布的Houdini引擎接口插件,你现在可以直接在Cinema 4D中打开HDA文件。类似于C4D的生成器,你可以修改HDA文件的参数来获得你想要的效果。最厉害的是,Houdini引擎始终是在后台工作,基本不占用资源,你在C4D中修改HDA文件的参数可以实时看到结果!
Hello Guys,
Hope you all are doing well. I wanna share a plugin for Cinema4D that i saw in morning (IST). Here is the dropbox link for that plugin. If you have any issue in downloading please referrer this link also it is tutorial video as well how it works :
Note : If you don't have dropbox login just click view only and download the plugin also i don't no where to paste this plugin if you found that please share in this thread it will be helpful but here is the instruction from Maxon to install the plugin :
CINEMA 4D HOUDINI ENGINE INTEGRATION – PUBLIC BETA
Plug-in Build: 136548
Compatible Houdini version: 14.0.367 · Compatible Cinema 4D version: 16.050 (Cinema 4D R16 SP3)
To install the Houdini Engine plug-in for Cinema 4D, please follow these steps:
1. Exit Cinema 4D
2. Copy the files from this archive’s “modules” folder to the “modules” folder
of your Cinema 4D installation
3. Overwrite the “resource\modules\houdiniconfig” folder of your Cinema 4D installation with the
“resources\modules\houdiniconfig” folder from this archive
4. Overwrite the “resource\modules\houdiniengine” folder of your Cinema 4D installation with the
“resources\modules\houdiniengine” folder from this archive
5. Launch Cinema 4D
6. If the plug-in was installed successfully, you will see a “Houdini Engine” entry under the “Pipeline”
menu. If it only contains the “Get Houdini Installer...” command, it means that the Houdini
installation required by the plug-in was not found.
Use this command to download and install Houdini Engine for your computer, then restart Cinema
4D. The “Houdini Engine” menu should now contain all the Houdini plugin commands.
To activate your 30 days Houdini Engine trial after downloading the Houdini Engine, please follo
these steps:
Windows:
1. Go to the Start Menu
2. Select All Programs
3. Navigate to Side Effects Software > Houdini 14.0.367 > Utilities
4. Select Command Line Tools
5. Type: hkey -n 9 and press Enter
6. Follow the rest of the instructions
OR:
1. Open the terminal
2. Run:
"C:\Program Files\Side Effects Software\Houdini 14.0.367\bin\hkey.exe" -n 9
MAXON Computer GmbH – Max-Planck-Str. 20 – D-61381 Friedrichsdorf – +49 (0)6172 5906 0
Mac:
1. In the Finder top menu click on Go > Applications
2. Go to Houdini 14.0.367 > Utilities
3. Double click on Houdini Terminal
4. Type: hkey -n 9 and press Enter
5. Follow the rest of the instructions
OR
2. Run: open /Applications/Houdini\ 14.0.367/Administrative\ Tools/License\
Administrator.app --args -n 9
Have a Great Day!
上一篇:C4D最强破碎插件Nitro4D NitroBlast v2.02 汉化稳定版
下一篇:[Amped版] C4D 阿诺德渲染器v1.2.1插件汉化版 SolidAngle Cinema 4D To Arnold v1.2.1
2016-9-5 17:00
好东西。。。
2016-9-6 09:47
东西不错,支持楼主继续分享更棒的资源给大家。
2016-9-6 10:56
2016-11-16 19:12
好强大,有很多学习的地方可以看看!!!
2016-12-7 09:40
2016-12-24 17:08
有人分享才会有进步 分享让我们体会到快乐哦 嘿嘿
2017-1-12 11:54
感谢楼主分享!不错的插件!!!!!!!
2017-1-20 00:01
谢谢分享!!!!!!!!!!!
2017-2-15 09:34
