素材名称:C4D茶杯转盘游戏游乐场娱乐模型
内容标签:娱乐玩具模型、茶杯模型、游乐场模型、橡胶、速度 C4D模型
分类属性:娱乐玩具
模型格式:C4D、OBJ
包含细节:材质 .
渲染插件:软件自带、VRAY渲染器
工程归属:纯模型
Teacups is an amusement ride characterized by cup-style spinning vehicles atop a turntable-like floor. Typically, each set of six teacups has a center bearing mounted underneath, similar to a car wheel bearing mounted on a circular floor capable of turning 360°. The circular floor of the cup sits on a larger turntable-like floor. This is driven by a motor through a starting device; the ride when started begins to spin slowly and build up speed as the operator applies more power. When in operation, the ride operator spins each cup while the turntable spins the entire ride base. They are driven by a motor fixed to the base in either the middle or the outside, the motor fixed in the middle has a gearbox which changes direction, as well as gives the correct ratio to the desired speed. The motor fixed on the outside again has a gearbox, but is attached to a small rubber wheel which sits along the rim under the platform. Either way, the end result is achieved and under modern health and safety guidelines, children's rides should not spin faster than eight times per minute.
茶杯是一种娱乐游戏,其特点是杯式纺纱车在转盘式地板上。通常,每组六个茶杯具有安装在下面的中心轴承,类似于安装在能够旋转360°的圆形地板上的车轮轴承。杯子的圆形地板位于更大的转盘状地板上。它由电机通过起动装置驱动;当驾驶员开始缓慢旋转并且随着操作者施加更多动力时建立速度。在操作时,乘客操作者旋转每个杯,同时转台旋转整个座基。它们由在中间或外侧固定到基座的电动机驱动,固定在中间的电动机具有改变方向的齿轮箱,以及给出与期望速度正确的比率。固定在外部的电机再次具有齿轮箱,但是连接到沿着轮辋位于平台下方的小橡胶轮。无论哪种方式,最终的结果是实现的,根据现代健康和安全指南,儿童骑乘不应超过每分钟8次。
