C4D曲面建模工具插件 Cineversity CV-SPLINES TO OBJECTS R17+ - 菜鸟C4D
 热度: 175 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2016-10-28 06:01 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
15177
173
CV-Splines to Objects: Extrude, Lathe, Loft, & Sweep Splines with Powerful Single-Click Commands
CV-Splines to Objects is a set of plugins that speed up the process of converting splines into polygonal objects. Follow along with this video to model an Electric Guitar from pre-drawn splines in just a few clicks. Tools covered include:
CV-Extrude Splines: Extrudes multiple splines in a single click. Intelligently names your objects. Don't sweat the small stuff, let us.
CV-Lathe Splines: Lathe objects in context. No need to reposition your reference to world-center, or only lathe around World Y. Lathe multiple objects where you want them to be, but give each it's own object for easier texturing. Save yourself the annoying work of perfectly lining up points on the Y-Axis in order to create a water-tight mesh.
CV-Sweep Splines: 9 times out of 10 you just want to create a pipe with an easily controlled number of segments. Now you can select as many splines as you want and easily sweep them with an N-Side polygon in a single click. Use the Scale to immediately after sweeping to adjust the pipe radius by eye.
CV-Convert to Loft: Select splines in space, and then loft them. Stop trying to differentiate between 15 splines named Spline.7.
CV-Render Splines: Make your splines renderable with a single-click. No need to remember to add hair tags to multiple objects, or a render effect, or special tags if you're working with deformed splines.
CV样条曲线与对象:挤压,车床,放样和扫描样条与强大的单击命令
CV-Splines to Objects是一组插件,可以加快将样条曲线转换为多边形对象的过程。按照此视频,只需几次点击,就可以从预先绘制的样条曲线建模电吉他。所涵盖的工具包括:
CV挤出样条:单击可挤出多个样条。智能地命名你的对象。不要出汗的小东西,让我们。
CV车床花键:上下文中的车床对象。无需重新定位您的参考世界中心,或只有车床周围世界Y.车床多个对象,你想要他们,但给每个它自己的对象,更容易纹理。保存自己在Y轴上完美排列点的恼人的工作,以创建一个防水网。
CV扫描样条:10次中的9次,您只想创建一个具有容易控制的段数的管道。现在你可以选择任意数量的样条曲线,只需单击一下就可以轻松地用N面多边形进行扫描。在清扫后立即使用缩放,通过肉眼调整管道半径。
CV-Convert to Loft:在空间中选择样条,然后放样。停止尝试区分名为Spline的15个样条。
CV渲染样条:使您的样条一键式可渲染。不需要记住添加头发标签到多个对象,或渲染效果,或特殊的标签,如果你使用变形的样条。
上一篇:C4D 阿诺德渲染器v1.4插件汉化版 Arnoldv1.4.0.For.Cinema4D.R16-R18 [WIN]
下一篇:C4D可控房屋卧室预设汉化版
谢谢,辛苦啦,支持你的贡献,继续努力
2016-10-28 08:23
不错不错,赞一个,收藏了。不错不错,赞一个,收藏了。
2016-10-28 08:30
2016-10-28 08:32
2016-10-28 09:55
2016-10-28 10:02
不错不错,很棒的东西,谢谢分享!!!!!!!!
2016-10-28 10:17
插件不错,谢谢楼主分享!!!!!!!!!!
2016-10-28 10:55
很棒的东西!!!!  感谢分享  收藏了
2016-10-28 10:57
最全面的C4D資源網站盡在[  C4DCN.com  ]!
2016-10-29 00:55
