Houdini fracture asset v0.6 - for C4D - 菜鸟C4D
 热度: 114 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2018-7-7 23:07 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
9626
124
Note : If you don't have dropbox login just click view only and download the plugin also i don't no where to paste this plugin if you found that please share in this thread it will be helpful but here is the instruction from Maxon to install the plugin :
CINEMA 4D HOUDINI ENGINE INTEGRATION – PUBLIC BETA
Plug-in Build: 136548
Compatible Houdini version: 14.0.367 ? Compatible Cinema 4D version: 16.050 (Cinema 4D R16 SP3)
To install the Houdini Engine plug-in for Cinema 4D, please follow these steps:
1. Exit Cinema 4D
2. Copy the files from this archive’s “modules” folder to the “modules” folder
of your Cinema 4D installation
3. Overwrite the “resource\modules\houdiniconfig” folder of your Cinema 4D installation with the
“resources\modules\houdiniconfig” folder from this archive
4. Overwrite the “resource\modules\houdiniengine” folder of your Cinema 4D installation with the
“resources\modules\houdiniengine” folder from this archive
5. Launch Cinema 4D
6. If the plug-in was installed successfully, you will see a “Houdini Engine” entry under the “Pipeline”
menu. If it only contains the “Get Houdini Installer...” command, it means that the Houdini
installation required by the plug-in was not found.
Use this command to download and install Houdini Engine for your computer, then restart Cinema
4D. The “Houdini Engine” menu should now contain all the Houdini plugin commands.
To activate your 30 days Houdini Engine trial after downloading the Houdini Engine, please follow
these steps:
Windows:
1. Go to the Start Menu
2. Select All Programs
3. Navigate to Side Effects Software > Houdini 14.0.367 > Utilities
4. Select Command Line Tools
5. Type: hkey -n 9 and press Enter
6. Follow the rest of the instructions
OR:
1. Open the terminal
2. Run:
"C:\Program Files\Side Effects Software\Houdini 14.0.367\bin\hkey.exe" -n 9
MAXON Computer GmbH – Max-Planck-Str. 20 – D-61381 Friedrichsdorf – +49 (0)6172 5906 0
Mac:
1. In the Finder top menu click on Go > Applications
2. Go to Houdini 14.0.367 > Utilities
3. Double click on Houdini Terminal
4. Type: hkey -n 9 and press Enter
5. Follow the rest of the instructions
OR
2. Run: open /Applications/Houdini\ 14.0.367/Administrative\ Tools/License\
Administrator.app --args -n 9
Have a Great Day!
上一篇:C4D插件 展UV贴图编辑工具盒子插件汉化版 Coffeestock UVToolbox v1.9 R19
下一篇:C4D插件 样条绘制模型建模插件汉化版 Nitro4D NitroModel v1.0.1 R13-R19
菜鸟C4D,与你一起从零开始...C4DCN.com
2018-7-8 14:46
2018-7-8 22:32
将此回复同步到 腾讯微博 | 回帖后跳转到最后一页
2018-7-9 08:43
2018-7-9 09:58
广告是个什么鬼,还自动播放呀?
2018-7-9 16:14
而他个人塔尔特热话题然后身体会让他
2018-7-10 12:51
感谢分享!!!!!!!!!!!!!!!~~~~~~
2018-7-10 22:18
sujvsujvsujvsujvsujvsujvsujvsujvsujv
2018-7-11 14:12
2018-7-11 15:25
