C4D插件 变换工具插件汉化版 TransformTool - 菜鸟C4D
 热度: 190 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2015-1-13 17:31 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
15145
191
Transform
变换
This is a tool plugin inspired by the transform tool in Photoshop for example. It has the special ability to change the size parameters of the basic primitive objects and scale these objects non-uniformly. It displays a cage with handles which can be dragged to move, scale, rotate and shear the selection. It also displays four icons which can be clicked to switch between modes. Snapping is supported, meaning the handles snap accordingly.
这是一个工具,插件由变换工具在PS图象处理软件例如。它具有特殊的能力改变尺寸参数的基本图元对象和这些对象的非均匀尺度。它显示一个笼的把手可以拖着走,规模,旋转和剪切的选择。它还显示四个图标,可以点击模式之间切换。抢购的支持,处理单元相应的意义。
Note: Beside polygon objects of course, it really can only scale primitives like Cube, Sphere, Cylinder, etc. In some cases the object cannot be fit to the cage. For example when using a rotated object or a object with only one degree of freedom like a sphere. It will still try to do something reasonable.
注:除当然多边形对象,它真的只能规模基本立方体,球体,圆柱体,等等。在某些情况下,对象不能适应笼子。例如使用一个旋转的对象,或只有一个程度的自由对象时,像一个球。它仍然会尝试做一些合理的。
Shearing only works with polygon objects.
与多边形对象剪切工作。
Spline tangents are not touched. I will fix this some day.
样条曲线的切线不感动。我会把这几天。
You can switch between move, scale, rotate, shear with ALT+1-4. This is hardcoded at the moment.
您可以切换之间的移动,旋转,比例,ALT + 1-4剪切。这是默认的此刻。
Hold Shift for quantization.
按住shift量化。
上一篇:[R13-16]UV变形器插件UVDeformer
下一篇:C4D插件 点塌陷插件汉化版 PointCollapse
好东西,谢谢!!!!!!!!!!!!!!
2015-1-13 20:38
2015-1-14 11:02
需要这样的插件。非常感谢
2015-1-14 20:36
2015-1-14 21:13
谢谢分享
2015-1-14 22:08
2015-1-15 17:53
好像有点意思下来看看先有有点意思
2015-1-16 11:00
谢谢楼主的分享,辛苦了,非常感谢了
2015-1-16 12:06
RE: [R13-16]变换工具插件汉化版TransformTool [修改]
2015-1-16 18:46
