C4D插件-cmnodes节点材质插件下载(包含教程) cmnodes – Cinema 4D nodes QuickTi - 菜鸟C4D
首页 › 分类资源 › C4D插件 发布时间:2020-1-26 17:56 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
4476
47
This release is essentially the same as the previous 1.5.07 build, but now with support for R13.
I am still working on new stuff as I can, and there have been some interesting developments with the VrayForC4D team (more on that later). I'm working on a variety of specular and reflection models, and I've got some more optimizations and improvements cooking.
20140511 I've received a couple of suggestions from Maxon for getting the Subsurface Scattering (SSS) shader to work with cmNodes. Both methods involve sneaking in a SSS shader to force the cache building.
The first (cmnodes_sss_workaround_01.c4d) involves adding a layer shader to an unused material channel (the Color channel in the simple example) and hiding a SSS shader in there.
The second (cmnodes_sss_workaround_02.c4d) involves putting the SSS shader in a material which is then applied "underneath" the cmNodes material.
Update for R17 - 20150909
cmNodes 1.5.89 has been built for R15 and will work with R17. This is a recompile of the previous build, so no new features or major changes.
此版本与先前的1.5.07版本基本相同,但现在支持R13。
我仍在努力研究新事物,并且VrayForC4D团队进行了一些有趣的开发(稍后将进行介绍)。我正在研究各种镜面反射和反射模型,并且还进行了一些优化和改进。
20140511我已经从Maxon那里收到了一些建议,可以使Subsurface Scattering(SSS)着色器与cmNodes一起使用。两种方法都涉及潜入SSS着色器以强制建立缓存。
第一个(cmnodes_sss_workaround_01.c4d)涉及将图层着色器添加到未使用的材质通道(在简单示例中为“颜色”通道),并在其中隐藏SSS着色器。
第二个(cmnodes_sss_workaround_02.c4d)涉及将SSS着色器放在材质中,然后将其应用在cmNodes材质“下方”。
R17的更新-20150909
cmNodes 1.5.89已针对R15构建,并将与R17一起使用。这是对先前版本的重新编译,因此没有新功能或重大更改。
经测试支持R20版本,理论支持R21
上一篇:C4D灯光插件汉化版 white lights
下一篇:C4D xpresso节点生成马赛克像素砖块预设汉化版下载 Mosaic Cinema 4D preset
2020-1-26 17:57
2020-1-27 16:53
2020-1-29 11:29
2020-2-3 00:26
2020-2-8 16:37
2020-2-18 23:45
2020-2-24 23:54
2020-2-26 13:40
2020-3-1 19:29
12345下一页
