AE视频慢镜头升格插件 REVisionFX Twixtor Pro 6.0.7 WIN - 菜鸟C4D
首页 › 后期处理 › AE插件 发布时间:2022-2-22 11:23 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
2092
10
AE视频慢镜头升格插件 REVisionFX Twixtor Pro 6.0.7 WIN是一个视觉特效、其他插件,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC,插件使用教程:无教程。支持PC系统安装使用,下载检索码QL220217AC-36。当前ae插件素材由用户慧彩分享在AE插件区,更多关于视频教程、视频素材、慢镜头的ae插件请访问菜鸟c4d网站!
AE慢镜头插件 REVisionFX Twixtor Pro 6.0.7 for Adobe Win64
Twixtor是AE常用的升格插件,对于不同的视频素材设置的参数也不一样,大家可以到官网观看视频教程。
Twixtor raises the bar in motion estimation. Twixtor is much more accurate, tracks objects farther, and exhibits fewer artifacts when there are objects crossing in the scene. This means less tearing and stretching of objects as they cross or go out of the frame.
新特性:
Warping and interpolation of frames to “time warp” input footage.
Smart processing of interlaced material
Stretching of a sequence using a single scaling parameter.
Keyframable retiming for complete control on a frame by frame basis.
Frame rate conversions made easy (Important Note: frame rate conversions are supported only from within After Effects and Combustion ).
8 and 16 bits per channel processing. Unclamped floating point image support in After Effects 7.0 or later
Option to automatically enhance dark imagery or imagery with poorly defined edges. In many cases, footage that was difficult to track becomes much more well-behaved upon retiming.
Contains an option to add or remove motion motion blur, as appropriate.
Support for marking material so that Twixtor does not motion-interpolate across a cut.
After Effects only: ability to remap audio and video using AE’s time remapping tools but using Twixtor “under the hood”
兼容性:
Adobe After Effects 7.0 and up, including 64-bit support for CS5 and up.
Adobe Premiere Pro CS4 and up.
What’s new in version 6.0.7?
Fixes a crashing bug that could happen when scrubbing or positioning the current time pointer on the timeline.
上一篇:AE+PR色彩匹配优化插件 REVisionFX RE:Match v1.3.4
下一篇:AE蓝宝石插件 GenArts Sapphire v7.06支持CS5-CC Win64
c4d地球模型谁有高精度的?别的网站下载的都太垃圾了简直没法用啊
2022-2-22 11:24
希望以后C4D能集成一个非常智能的渲染器出来,我就不用太辛苦的渲染了。
2022-2-22 11:27
c4d折射材质太难调了,搞了一下午都没弄明白咋弄
2022-2-22 22:45
2022-2-23 04:44
2022-2-23 04:44
这东西真的是C4D做的吗?谁来告诉我
2022-3-9 11:39
C4D曲面建模是不是就是细分曲面工具?感觉和maya的曲面不太一样是吗
2022-3-9 22:19
刚学习C4D,有没有好的入门教程学习一下?
2022-3-10 01:15
以为大家都是大神,原来只有我一个c4d菜鸟
2022-3-10 10:49
