AE+PR色彩匹配优化插件 REVisionFX RE:Match v1.3.4 - 菜鸟C4D
首页 › 后期处理 › AE插件 发布时间:2022-2-22 11:23 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
1176
10
AE+PR色彩匹配优化插件 REVisionFX RE:Match v1.3.4是一个调色插件,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC,插件使用教程:无教程。支持PC系统安装使用,下载检索码QL220217AC-35。当前ae插件素材由用户慧彩分享在AE插件区,更多关于白平衡、色彩、匹配、优化、插件的ae插件请访问菜鸟c4d网站!
色彩匹配插件 REVisionFX RE:Match v1.3.4 for After Effects and Premiere Pro (Win64)
色彩匹配插件 REVisionFX RE:Match v1.3.4,适用于AE和Premiere,Win64.RE:Match可以匹配不同镜头之间的色彩,曝光,白平衡,局部色彩匹配等,如果你用不同摄像机拍了同一个场景,用这个插件匹配他们之间的各种参数达到匹配再合适不过了。1.3.4较之前修正几个bug
RE:Match来匹配一个视图的视频或电影到另一个,这样看起来好像是用相同的相机和设置。RE:匹配假设两幅图像序列是大约在同一位置但也许没有同时拍摄或从相同的观点
RE:Match is a set of plug-ins to match one view of video or film to another so that it looks as if it was shot with the same camera and settings. RE:Match assumes that both image sequences are taken roughly at the same location but perhaps were not shot at the same time or from the same point-of-view
Features:
– Ability to globally color correct one sequence to match another.
– Ability to globally color correct a whole sequence based on a particular point in time, or can be performed separately for each pair of frames in both sequences.
– Ability to perform automatic global (whole image) color correction based on a smaller window of pixels for each of the image sequences.
– Works well with over bright values and very wide dynamic ranges.
– Matching for stereo pairs takes advantage of internal per-pixel registration using optical flow methods.
– Stereo pair matching takes into account occlusions.
– Stereo pair matching takes into account that the two images may not have corresponding details at some of the edges of the frame.
– Stereo matching has controls for making details, such as reflections, lens flares and specular highlights match between the two views.
– Methods provided to remove or attenuate on-lens artifacts (such as water drops on a lens).
– Because RE:Match uses internal pixel registration, stereo matching does not require image alignment prior to use.
– Visualization modes are provided to visualize and guide what RE:Match is doing internally.
– Not limited to any particular resolution of images.
– Works on all bit depths, including HDR images.
Compatibility
– Windows Vista, 7, 8 and up
– Adobe After Effects CS5 and up.
– Adobe Premiere Pro CS5 and up.
What’s new in version 1.3.4:
– RE:Match Color: The Limit % slider added in v1.3 is causing issues with many setups. Version 1.3.4 turns this option off until we have a more robust fix.
上一篇:AE字幕制作插件 NewblueFX Titler Pro 3.0
下一篇:AE视频慢镜头升格插件 REVisionFX Twixtor Pro 6.0.7 WIN
我的用户名是lvoeno18,请问慧彩你记住我了吗?
2022-2-22 11:23
谁带带我C4D入门,我刚接触CINEMA4D
2022-2-22 11:24
看来我是急需提升渲染技术了
2022-2-22 11:50
大家用的C4D电脑配置都是什么样的啊,我的电脑渲染C4D太卡了、
2022-2-22 21:10
咱们网站的C4D植物模型有树木的吗?感激不尽
2022-2-22 21:32
想问一下C4D材质球下载在哪里?我怎么没找到啊谁告诉我呗
2022-3-7 18:14
求一个c4d Redshift最新版渲染器插件,好心人发我一下谢谢
2022-3-7 18:21
非常棒的AE插件资源菜鸟C4D新人报道!
2022-3-8 01:47
抢沙发!楼主慧彩的东西必是干货,楼下保持队形!
2022-3-8 02:32
