AE工程文件共享同步脚本(含教程) Project Sync 3.0.1 - 菜鸟C4D
首页 › 后期处理 › AE插件 发布时间:2022-2-24 11:02 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
2474
10
这是一个其他脚本,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC,脚本使用教程:含教程。支持PC、MAC系统安装使用,下载检索码QL220217AC-55。当前ae插件素材由用户慧彩分享在AE插件区,更多关于AE脚本、共享、同步、工程脚本的ae脚本请访问菜鸟C4D网站!
AE工程文件同步脚本 Aescripts Project Sync 3.0.1+教程
不同用户之间可以很快的共享同一个工程文件,下载包含脚本和视频教程。
Project Sync 3 gives you the ability to share After Effects Project files between multiple users. The all new Sync 3 has been completely rewritten and offers new features and a stable platform to keep you and your team moving through the toughest deadline.
Sync gives you the ability to share After Effects Project files without duplicating content. Increase your productivity, start Syncing your files today.
Features:
– Share projects with other After Effects users
– Sync multiple projects
– No duplicate footage or comps
– Automatic notifications of any changes to project files
Quick Start Guide to using Project Sync 3
With Project Sync 3 there are now 2 different options for syncing your projects.
“Link Project”
You will use this option if you have already imported a project into your working project and want to watch it for updates.
Simply select the Imported Project’s folder in the project panel.
Click “Link Project” in your Project Sync panel.
Locate the .AEP that you imported and click “open”.
That’s it! Your Project should now be displayed in the “Linked Projects” list in the Project Sync panel. To check for updates, use the “Check for Updates” button.
“Share Comp”
You will use this option if you have a comp that you would like to export to another user.
Simply select the comp that you’d like to share in the project panel.
Click “Share Comp” in your Project Sync panel.
Click “ok” to save the current project.
You will now enter a name for the new project that has been created from your comp. By default it will be the same name as the selected Composition.
Once you’ve saved this new project, it will be imported into your project and replace the original comp.
That’s it! Your Project should now be displayed in the “Linked Projects” list in the Project Sync panel. You can check for updates with the “Check for Updates” button.
上一篇:AE自由变形+三维挤出插件下载支持CS5-6 Win+Mac
下一篇:AE运动图形切割动画脚本(含教程) Slice it Up v1.0
这个AE插件内容看起来不错,可是我不是VIP下载不了啊
2022-2-24 11:02
c4d用什么电脑配置?求楼主指点一下!
2022-2-24 11:02
谢谢楼主了,顺便问一下现在最新的XP粒子最新版本是4.0吗
2022-2-24 12:46
菜鸟真是个好网站,以前怎么就没有发现呢
2022-2-24 15:26
大家用的C4D电脑配置都是什么样的啊,我的电脑渲染C4D太卡了、
2022-2-24 15:37
十分感谢慧彩分享的AE插件素材,看的我太激动了
2022-3-5 17:47
看来我是急需提升渲染技术了
2022-3-5 17:47
听老师说C4D预设有很多,用起来很方便
2022-3-6 06:46
最近开始学习C4D了,发现菜鸟网站又好多好东西
2022-3-6 06:46
