这是一个MG脚本,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC,脚本使用教程:含教程。支持PC、MAC系统安装使用,下载检索码QL220217AC-56。当前ae插件素材由用户慧彩分享在AE插件区,更多关于视频教程、动画、动画脚本、运动图形、自定义的ae脚本请访问菜鸟c4d网站!
AE切割脚本 Aescripts Slice it Up v1.0
可以自定义切割的数量,可以完全控制碎片的位置和选装等属性。下载包含脚本和视频教程。
Slice it Up slices your footage into any number of slices and gives you full control over its position and rotation with the ability to re-randomise existing data.
Workflow is straight forward: select a layer you wish to slice, enter desired value for slices, check / uncheck two checkboxes, select Container Mode and hit Slice it Up. Sit back and watch the magic happen.
After slicing is finished you will see new composition that has Slider Controls attached to it. Parameters like Y Offset / X Shuffle / Z Space are meant to be animated. Choose between linear and randomised offset for those values. Combining them together with Rotation and Expansion will result in great and unique animation.
