AE复古照片像素化马赛克插件 Aescripts RetroDither - 菜鸟C4D
首页 › 后期处理 › AE插件 发布时间:2022-2-26 11:58 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
1501
10
这是一个视觉特效插件,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC,插件使用教程:无教程。支持PC系统安装使用,下载检索码QL220217AC-75。当前ae插件素材由用户慧彩分享在AE插件区,更多关于马赛克、复古、色彩效果、GPU插件、FC像素的ae插件请访问菜鸟C4D网站!
AE复古比特像素插件 Aescripts RetroDither
RetroDither 可以模拟FC复古像素效果,包含多种预设,基于GPU运算的
RetroDither is a GPU accelerated plugin for Adobe After Effects which allows to create stylized images with dithering and color schemes from retro game consoles and home computer platforms.
You could call it ‘save GIF for web’ on steroids on first sight, but in fact RetroDithering is capable to do so much more, having more than 10 different ordered and errordiffusion dithering algorithms and color palettes varying from several adaptive to classic hardware ones, such as ZX spectrum, CGA, MSX and many more.
Now you can do very authentic stylizing, if you’re trying to add some retro feeling into your motion graphics or footage.
特性功能:
20 different color palettes including C-64 and Apple II
Adaptive color palettes work pretty similar to the ones in e.g. Adobe Photoshop “Save for Web” dialog , while named after hardware ones (CGA, ZX Spectrum, C64 etc.) are mimicking actual ancient hardware limitations.
12 different dithering methods
RetroDither is generally capable of two types of dithering: error diffusion (including Floyd-Steinberg, Jarvis-Judice, Stucki, Atkinson, Burkes, Siera, Stevenson-Arce algorithms) and ordered dithering using Bayer matrix.
0 to 8x downscaling
Performs image downscaling for more stylized look.
Threshold slider
Is available to alter Bayer dithering algorithms, and also to manage 1-bit color palette mapping.
Grayscale
Performs additional grayscale conversion of the input. Note that color palette is applied after this operation, which means you won’t necessary have grayscale image on the output of the effect; instead, RetroDither will map shades of gray to colors of output palette, which might give you quite interesting results.
Seprentine scan
Alters all error diffusion based (non-Bayer) dithering algorithms, producing slightly different result (see the description).
Fully GPU Accelerated!
C4D高级随机文字马赛克动画效果渲染插件中文汉化版 z-ASCII Cinema 4D plugin
上一篇:AE自动文字路径动画脚本 Curva Script
下一篇:AE透明通道复杂抠像羽化蒙版一键抠图插件(含教程) EFX Keying Alpha
c4d折射材质太难调了,搞了一下午都没弄明白咋弄
2022-2-26 11:59
C4D建模太难了,谁来教教我多边形布线吧
2022-2-26 15:49
万分感谢,我是做设计的平时用C4D+AE简直就是绝配用起来太爽了
2022-2-27 02:30
菜鸟C4D的会员要到期了,先感谢楼主分享……
2022-2-27 02:49
2022-2-27 13:36
求一个c4d Redshift最新版渲染器插件,好心人发我一下谢谢
2022-3-5 17:31
菜鸟C4D有没有工业建模教程,最好是多边形布线的那种
2022-3-5 17:47
2022-3-5 19:34
看了慧彩分享的c4d人物建模教程之后,我终于会自己做人体模型了,哈哈哈哈哈哈
2022-3-6 02:34
