这是一个抠像/合成插件,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC,插件使用教程:含教程。支持PC系统安装使用,下载检索码QL220217AC-76。当前ae插件素材由用户慧彩分享在AE插件区,更多关于透明通道、抠图插件、羽化、蒙版、一键抠图的ae插件请访问菜鸟C4D网站!
透明通道抠像套装 Aescripts EFX Keying Alpha + 教程
一共17个抠像插件,可以解决很多复杂抠像问题:例如羽化蒙版,结合不同图层蒙版,一键抠图等,包含插件和视频教程
This suite of plugins consists of many tools developed over many years of compositing when off-the-shelf effects in After Effects would not provide satisfactory results. Some of them solve small problems, like softening an edge of a matte, others evolved into full blown keying solutions.
主要特性:
combine alpha mattes of different layers with one simple effect,
clean an alpha from small speckles left after keying noisy footage or difference matte,
feather a matte edge “outwards” – you don’t lose thin details,
remove a dark edge after keying – this happens when the camera had sharpening turned on,
tell the despiller which pixels he should despill and which to leave alone,
difficult spill case? Just select the pixels with spill on them and use any of the normal AE effects to remove it,
select pixels based on their color, luminosity or even transparency.
这个套装一共包含17个抠像插件:
Alpha Choke
Alpha Math
Alpha S’n’P
Alpha Select
Alpha Streaks
Color Select
Color Select HSL
Despill
Despill Advanced
Despill Brute
Edge Bleed
Edge Blur Keyer
Keyer
Keyer HSL
Luma Select
Spill Alpha
Despill Brute
