这是一个其他脚本,语言为英文。支持after effects软件版本:CS4、CS5、CS5.5、CS6、CC,脚本使用教程:含教程。支持PC、MAC系统安装使用,下载检索码QL220217AC-78。当前ae插件素材由用户慧彩分享在AE插件区,更多关于解组、预合成、3D图层、摄像机灯光、无损的ae脚本请访问菜鸟C4D网站!
AK VideoCopilot教程153期:3D图层预合成脚本+教程 3D Pre-Compose
这个脚本是用来干什么的呢?3D Pre-Compose可以对3D图层预合成,不会丢失摄像机灯光属性,同时,表达式也不会被破坏!!!下载包含脚本和教程
What is this script for? The 3D Pre-Compose Script makes it easy to pre-compose 3D-aware layers by automatically copying all cameras & lights into the new comp with linked expressions! Just watch the tutorial to see all the amazing possibilities! Plus it’s Free!
脚本的作用:
Create displacement maps out of 3D aware layers
Isolate 3D layers for different lighting setups in the same scene
Disable DOF for certain layers
Lens Flare obscuration maps in 3D: For Element 3d & Particular etc
Apply 2D effects to a 3D layer in screen space
