星空材质着色器插件Extended Starfield - 菜鸟C4D
 热度: 97 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2016-5-19 16:34 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
8703
97
222.gif 这个插件属于材质、其他分类,支持cinema4d软件版本为:R13、R14、R15、R16、R17、R18。语言为英文,系统支持Windows、MAC。可以在软件材质通道位置找到本工具。当前素材由设计师用户:admin分享,更多关于材质插件、着色器插件、星空教程、星空插件、星空材质、插件着色器的内容请访问本网站。
This is a shader plugin to render star field backgrounds for space scenes. It is similar to the build-in star field shader but with a lot of options.
Basic usage: The maximum diameter of the stars is set as pixels in screen space. The distance between the stars is set by the UV-Spacing parameter. That means the distance is measured in UV space. You will need to adjust this spacing when you change your mapping parameters. Furthermore the shader cannot handle arbitrarily large stars. Their diameter may not exceed the spacing in between them. Keep in mind though that the respective parameters are measured in different spaces.
There are channels for auxiliary shaders to determine the spatial density distribution of stars (Density Map), and their brightness distribution (Intensity Map). In addition the brightness can be controlled by probability distribution functions (Intensity PDF/Dark Intensity PDF) which determine the probability that a star has a certain brightness. The Dark Intensity PDF is used when an spatial intensity map is set. The final brightness is interpolated between the values picked from the Intensity/Dark Intensity PDFs. Analogously you can set a probability distribution for the star size. Link Size to Intensity means that bright stars are also large and vice versa.
上一篇:表面着色效果器材质插件Things On Surface Shader
下一篇:16套C4D Welter Site插件合集6 sets of Cinema 4D Welter Site Collection widget
楼主很专业,牛逼吹的一流的,看来菜鸟不菜鸟啊!
2016-5-19 17:56
2016-5-20 11:06
谢谢分享!!!!!!!!!!!!!
2016-5-20 13:24
谢谢分享!!!!!!!!!!!!!
2016-5-20 21:29
支持下
2016-5-23 16:43
C4D插件汉化,就上C4DCN.com 专注C4D资源分享
2016-6-2 16:39
东西不错,支持楼主继续分享更棒的资源给大家。
2016-7-26 11:49
2016-8-3 04:27
2016-8-3 06:24
