16套C4D Welter Site插件合集6 sets of C4D Welter Site Collection widget
安装:将 zip 文件的内容解压到 plugins 目录中。 它存在于两个可能的位置。 一个直接在C4d安装目录下。 另一个位于用户数据目录中,如 C4d 的首选项对话框中所示。 任何一个都可以使用。
Installation: Extract the contents of the zip file into the plugins directory. It exists in two possible locations. One directly in the C4d installation directory. The other one is in the user data directory as shown in C4d's preferences dialog. Either can be used.
UVtoObject
Generates polygon objects from uv maps. Use polygon modeling tools on UVs!
CopyPastePolys
Provides Copy/Paste capability for polygons
Point Collapse Tool
Tool plugin to merge two mesh point together
Transform
Transform tool inspired by Photoshop
Duplicate Object
Minimalistic generator to make multiple copies of objects
Noise Deformer
Deforms objects based on noise functions
SplineConnector
Generator which gathers child splines into a single one
SplineNoiseDeformer
Deforms splines in perpendicular direction based on noises
UV Deformer
Place objects on surfaces via uv maps
Smooth
Powerful mesh smoothing plugin. Comes as deformer and dialog based
Atmosphere Shader
Physical atmosphere material for orbital views
Cellular Shader
Renders cellular noise functions
Extended Starfield
Very customizable 2d starfield shader
ThingsOnSurface Shader
Renders randomly distributed brush stamps
Time Shift
Changes the time value for the evaluation of shaders
