C4D多通道渲染的时候,可以轻松指定和删除缓冲渲染通道(Object Buffer),删除不必要的通道m,重命名等多种功能
Flash Buffer for Cinema 4D is a plugin that helps you to create Object Buffer channels when you need to prepare scene for rendering. With this plugin you can also quickly and easily assign the available channels, delete unnecessary or select objects to which it are assigned. Rename function will help specify the names of the results of rendering passes, as well as convenient to distribute all the sequences on the subdirectories.
