C4D实时视图渲染器插件汉化版 FrostSoft PixelBerg v1.9b Plug-in Cinema 4D - 菜鸟C4D
 热度: 282 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2016-11-20 01:02 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
18825
303
真正的实时渲染,所见即所得,体验游戏引擎般的极速享受...
New Sky System
The Sky System in PixelBerg has been reimagined and streamlined. Now, there is only a single input for lat-long image files. This makes for a cleaner workflow, but also improves on the quality of lighting from the sky system. The Sky System alls ads a new feature that lets you set a sky object as the “default sky”.
Rendering Improvements
Standard render spot effects are now passed to the GPU. This means that rendering will be faster over previous versions when using the standard renderer. Pre 1.9 post effects were done on the GPU and took up most the rendering time now that they are on the GPU they are virtually instantaneous depending of course on the output size.
Improved AA Options
A new SuperSampling AA method makes its way into the latest release. The method will basically render the whole scene at a larger scale, filtering that output down to the render size.
With R18 is PixelBerg Still Viable?
Cinema 4D R18 added some new viewport features, that drew into question if a product like PixelBerg would even be necessary.
In fact this question was why the latest version took so long for release. After much pondering, the developer conceded that C4D’s Viewport improvements only helps PixelBerg moving forward. So in short PixelBerg’s future with your help and support looks bright and there is still lots and lots of new things to add and improve.新天空系统
PixelBerg中的Sky系统已经重新设计和精简。现在,对于lat-long图像文件只有一个输入。这使得工作流程更加清洁,同时也提高了天空系统的照明质量。 Sky系统为广告提供了一项新功能,可让您将天空对象设置为“默认天空”。
渲染改进
标准渲染点效应现在传递到GPU。这意味着在使用标准渲染器时,渲染将比以前的版本更快。 Pre 1.9的后期效果是在GPU上完成的,并占据了大部分的渲染时间,现在他们在GPU上,他们几乎是瞬时的,当然取决于输出的大小。
改进的AA选项
新的超级采样AA方法进入最新版本。该方法将基本上以更大的尺度渲染整个场景,将该输出过滤到渲染尺寸。
R18是PixelBerg仍然可行吗?
Cinema 4D R18增加了一些新的视口功能,这使人怀疑,如果像PixelBerg这样的产品甚至是必要的。
事实上,这个问题是为什么最新版本花了这么长的时间来发布。经过多番思考,开发人员承认,C4D的Viewport改进只有帮助PixelBerg向前迈进。所以在短暂PixelBerg的未来,你的帮助和支持看起来明亮,仍有很多很多新的东西,需要添加和改进。
上一篇:C4D快速距离测量渲染插件 C4DZone MeasureIt 1.0 for Cinema 4D
下一篇:C4D插件 适用于R18版本的realflow v 1.02.0096(WIN\MAC)安装XX中文版
这个插件和R18自带的比较 区别是什么??、、有必要?
2016-11-20 10:35
签到天数: 27 天
[LV.4]偶尔看看III
主题
137
积分
R13
Rank: 3Rank: 3
积分667
发消息
2016-11-20 10:55
333333333333333333333333333333333333楼
2016-11-20 12:19
菜鸟C4D,与你一起从零开始...C4DCN.com
2016-11-20 12:21
感谢大佬分享。。。。。。。。。。。
2016-11-20 13:44
谢谢分享!下载下来试试看看效果如何,学习一下!
2016-11-20 13:50
这个没用过,下载回去试试看,新的gpu渲染?
2016-11-20 14:00
2016-11-20 14:01
这个没用过,下来试试,感谢6666666666666
2016-11-20 16:22
