C4D快速距离测量渲染插件 C4DZone MeasureIt 1.0 for Cinema 4D - 菜鸟C4D
精选插件 C4D快速距离测量渲染插件 C4DZone MeasureIt 1.0 for Cinema 4D
 热度: 209 [ 复制链接 ]
首页 › 分类资源 › C4D插件 发布时间:2016-11-14 16:23 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
16116
204
C4D插件-距离测量插件 C4DZone MeasureIt 1.0 for Cinema 4D R12-R16
C4DZone MeasureIt可以用来测量空间中任意两个点(同一对象或者不同对象)的距离,
在视频设计中可以作为辅助元素使用,
可测量房屋,建筑等其他模型,使用非常灵活
MEASURE IT PLUGIN
Measure It is a Cinema 4D plugin that measures the distance between two objects and renders it thanks to a parametric customizable object.
Thanks to its design and flexibility it's ideal for all technical designers who need to show part dimensions on their renders or animations.
You can misure objects, rooms, buildings etc etc.
Also thanks to its integrated point tracking feature animating your object causes automatic animation of the MeasureIt object without any effort.
Within the plugin you will find a wizard procedure that helps user to setup the scene and track the two desired points.
These are the 4 cases implemented within the wizard:
1° case
If user leaves the objects unselected on the scene by calling the wizard button the plugin will create two null objects and measure the distance between them.
You are free to move them away and place them where you need, the plugin will track them automatically
2° case:
If user selects two objects the plugin will measure the distance between their axes center
3° case:
If the objects are polygon or spline type and you leave only one point selected the plugin will use it instead of axis center
4° case:
If user selects 2 points of a spline or polygon object the plugin will measure the distance between them.
The main object "MeasureIt" is a multisegment spline so you can use it together with Nurbs Objects.
The wizard will help you to setup the scene and add sweep or extrude objects automatically.
The MeasureIt object is fully customizable, watch video demonstration for more information.
The plugin works with all editions of Cinema 4D R13/14/15 (Prime, Broadcast, Visualize, Studio) and with all cinema 4D compatible engine renderers (V-Ray etc).
Cinema4D and system requirements:
-Cinema4D Version 13/14/15
-OSX Snow Leopard or greater
-Windows 7 32/64 bit or greater
Measure It is available at our plugin section store at price of 15,00 euro + VAT
The plugin is developed by Matteo Porchedda from C4Dzone Staff.
上一篇:C4D Corona Alpha V6 RC2 渲染器汉化版
下一篇:C4D实时视图渲染器插件汉化版 FrostSoft PixelBerg v1.9b Plug-in Cinema 4D
感谢楼主分享 希望精品多多!!!!!
2016-11-14 17:26
henhao de ,bucuo de ,xiexie fenxiang
2016-11-14 18:48
感谢楼主分享 希望精品多多!!!!!
2016-11-14 21:20
好东西。。。
2016-11-15 01:00
可以用来测量空间中任意两个点(同一对象或者不同对象)的距离     赞啊
2016-11-15 09:52
2016-11-15 10:13
好学习天天向上好好学习天天向上好好学习天天向上
2016-11-15 12:48
感谢楼主分享 希望精品多多!!!!!
2016-11-15 15:02
感谢楼主分享 希望精品多多!!!!!
2016-11-15 15:03
