WINDOWS在CINEMA 4D启动时声明错误:“找不到LIBMMD.DLL” - 菜鸟C4D
首页 › 综合交流 › 技术交流 发布时间:2021-10-19 13:16 @11年菜鸟C4D自学网站,专业 | 专注 | 全面
1490
原因:
libmmd.dll 是 Cinema 4D 和您机器上的其他一些程序首先需要的 dll 文件。
程序内部的一些特殊功能需要它。
通常,此文件会随 Cinema 4D 自动安装。
如果文件未从系统正确保存或已被其他程序修改,则可能会导致问题。
解决方案:
  • 您实际上缺少两个 DLL 文件:libmmd.dll 和 svml_dispmd.dll;有时这些文件会因多种原因被 Windows 丢失。幸运的是,这个问题很常见,这些 DLL 文件与您的 Cinema 4D 安装一起打包,以防万一您需要替换它们。只需转到 C:\Program Files\MAXON\Cinema 4D\resource\libs\win64 并将 libmmd.dll 以及 svml_dispmd.dll 从这里复制到 C:\Windows\System32 文件夹中。执行此操作后,请尝试再次启动 Cinema 4D;它现在应该正常启动。
  • 如果尝试 1 并重新启动计算机后问题仍然存在,请在您的计算机上搜索该文件。通常该文件位于:
    C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler
    删除该文件并重新启动计算机。
    打开 Cinema 4D 安装介质上的文件夹“\bin\data\redist\”并
    安装文件“ww_icl_redist_intel64_2016.4.246.msi”。
    再次重新启动计算机后,程序应该可以正常运行。
    由于此程序在不同程序的不同版本中使用,因此版本可能会不时更改并导致启动程序出现此类问题。
关于C4D安装后缺失libmmd.dll的正确修复方法
https://www.c4dcn.com/thread-6477.html
Cause:
libmmd.dll is a dll file needed for Cinema 4D firstly and some other programs on your machine.
It's needed for some special functions inside the programs.
Usually this files are installed automatically with Cinema 4D.
If the file isn't saved correctly from the system or has been modified by another program it could cause problems.
Solution:
You're actually missing two DLL files: libmmd.dll and svml_dispmd.dll; sometimes these files are lost by Windows for a multitude of reasons. Fortunately this problem is common enough that these DLL files come packaged with your installation of Cinema 4D just in case you need to replace them. Just go to C:\Program Files\MAXON\Cinema 4D\resource\libs\win64 and copy the libmmd.dll as well as the svml_dispmd.dll from here into your C:\Windows\System32 folder. Once you do this try launching Cinema 4D again; it should now launch normally.
If the problem persists after trying 1 and restarting the computer, please search the file on your computer. Usually the file is located here:
Delete the file and restart your computer.
Open the folder "\bin\data\redist\" on your Cinema 4D installation media and
install the file "ww_icl_redist_intel64_2016.4.246.msi".
After restarting the computer again, the program should run properly.
As this program is used in different versions from different programs, the version can change from time to time and cause such problems starting programs.
上一篇:C4D新版本软件里的S和R代表什么?有什么区别
下一篇:我在哪里安装R20及更高版本的插件?
