CleanMode is a plugin designed to allow users to easily switch back and forth between Cinema 4D’s standard set of viewport filters to a second custom set. The default behavior removes elements that will not render such as splines or the perspective grid, allowing a clear view of your scene.
CleanMode是一个插件,用户可以轻松地在Cinema 4D的标准视口过滤器之间切换到第二个自定义设置。 默认行为将删除不会呈现的元素(如样条线或透视网格),从而可以清晰地查看场景。
